Zum Hauptinhalt wechseln
Neato BOTVAC D5 Li-ion Battery Replacement
Was du brauchst
  1. Neato BOTVAC D5 Li-ion Battery Replacement, Li-ion Battery: Schritt 1, Bild 1 von 2 Neato BOTVAC D5 Li-ion Battery Replacement, Li-ion Battery: Schritt 1, Bild 2 von 2
    • Turn the Neato Botvac upside down so the brushes and wheels are facing upward.
    • Unscrew the two 24 mm captive screws holding the battery compartment shut.
    • They will not come out of the cover, since the battery is the most replaced part. They are located right under the main brush.
  2. Neato BOTVAC D5 Li-ion Battery Replacement: Schritt 2, Bild 1 von 2 Neato BOTVAC D5 Li-ion Battery Replacement: Schritt 2, Bild 2 von 2
    • Carefully pull the battery out of it's socket so you can clearly see the wires connecting it to the robot.
    • Carefully unplug the connection, freeing the battery.
Abschluss
Elijah Baker
220 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 3-3, Konn Fall 2023 Mitglied von UMass Dartmouth, Team 3-3, Konn Fall 2023
UMASSD-KONN-F23S3G3
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
What is each function of the wires that come out of the D5 14.4V 6.5a h 93.6 Wh battery?
Red-_________
White-_________
Black-_________
Black-_________
Blue-_________
Yellow-_________
sells-glisten0k@icloud.com - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 25
Insgesamt: 205
