Zum Hauptinhalt wechseln
Neato BOTVAC D5 Main Brush Motor Replacement
Was du brauchst
  1. Neato BOTVAC D5 Main Brush Motor Replacement, Side Brush: Schritt 1, Bild 1 von 1
    • Turn the Neato Botvac upside down so the brushes and wheels are facing upward.
  2. Neato BOTVAC D5 Main Brush Motor Replacement: Schritt 2, Bild 1 von 2 Neato BOTVAC D5 Main Brush Motor Replacement: Schritt 2, Bild 2 von 2
    • Firmly grasp and pull on the side brush and it will pop right off
  3. Neato BOTVAC D5 Main Brush Motor Replacement, Main Roller Brush: Schritt 3, Bild 1 von 2 Neato BOTVAC D5 Main Brush Motor Replacement, Main Roller Brush: Schritt 3, Bild 2 von 2
    • Pop the tabs shown on the main brush cover, and then pull. It should come right off. You can put it aside for now.
  4. Neato BOTVAC D5 Main Brush Motor Replacement: Schritt 4, Bild 1 von 2 Neato BOTVAC D5 Main Brush Motor Replacement: Schritt 4, Bild 2 von 2
    • The Main brush will pop right out when you attempt to remove it.
    • When replacing the main brush make sure to orient it correctly.
  5. Neato BOTVAC D5 Main Brush Motor Replacement, Main Brush Motor: Schritt 5, Bild 1 von 2 Neato BOTVAC D5 Main Brush Motor Replacement, Main Brush Motor: Schritt 5, Bild 2 von 2
    • Pull down the latch under the sensor and then carefully remove it from the unit.
  6. Neato BOTVAC D5 Main Brush Motor Replacement: Schritt 6, Bild 1 von 2 Neato BOTVAC D5 Main Brush Motor Replacement: Schritt 6, Bild 2 von 2
    • Flip the unit over and locate the gap next to the motor, on the same side the sensor was removed from. Insert your flathead screwdriver and twist lightly to pop off the motor.
  7. Neato BOTVAC D5 Main Brush Motor Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the wiring connecting the motor to the circuit board and remove the brush motor.
Abschluss
Laurent Kwan
337 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 3-3, Konn Fall 2023 Mitglied von UMass Dartmouth, Team 3-3, Konn Fall 2023
UMASSD-KONN-F23S3G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 24
Insgesamt: 168
