Einleitung
This guide will show you how to replace a faulty laser.
Was du brauchst
Pull the left and right sides away from the machine to unclip the bumper. This requires that you bend the plastic a little bit. Unclip one side a little bit and allow the prong to rest on the side of the machine. Then unclip the other side and pull off the bumper parallel to both sides
Looking from above, remove the two 11mm screws with a torx T10 screwdriver.
Begin by placing the robot on it's back and removing the six 11m screws using a Torx T10 screwdriver.
To remove the top, you must press in both of the clamps at the same time and push upwards.
Lift gently upon the top panel.
Unplug the clip located on the right side before completely removing.
Locate and unscrew the four 12 mm screws located in the black cap with the phillips #00 screwdriver.
Lift the black cap to reveal the laser.
Gently pull back on the gold laser to remove it from the socket.
Unplug the mini LCU clip by gently pulling up and remove the laser.
4 weitere Personen haben diese Anleitung absolviert.
9 Kommentare
lol. You don’t need to open it to replace the laser. The top is a clip on. Just pull it and remove 4 screws.
where do you buy the replacement laser?
I too would like to know where he got a replacement laser.
where do I buy a replacement laser?
bjurgensen79@gmail.com
Beverly Jurgensen
Where do I buy a replacement laser?
Beverly Jurgensen
