Zum Hauptinhalt wechseln
Neato Botvac D75 Brushes Replacement
Was du brauchst
  1. Neato Botvac D75 Brushes Replacement, Brushes: Schritt 1, Bild 1 von 3 Neato Botvac D75 Brushes Replacement, Brushes: Schritt 1, Bild 2 von 3 Neato Botvac D75 Brushes Replacement, Brushes: Schritt 1, Bild 3 von 3
    • To remove the rotary brush simply grasp it firmly and pull it off.
  2. Neato Botvac D75 Brushes Replacement: Schritt 2, Bild 1 von 3 Neato Botvac D75 Brushes Replacement: Schritt 2, Bild 2 von 3 Neato Botvac D75 Brushes Replacement: Schritt 2, Bild 3 von 3
    • Once you have everything out get the plastic opening tool and pry open the large black plastic piece.
    • With a little force it should come out.
    • The boxes show you were the clips are that hold this piece
  3. Neato Botvac D75 Brushes Replacement: Schritt 3, Bild 1 von 1
    • Once the black piece has been taken out, the brush just comes out easily.
Abschluss
Juan Cornejo
597 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S6-G5, Lacy Spring 2017 Mitglied von USF Tampa, Team S6-G5, Lacy Spring 2017
USFT-LACY-S17S6G5
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
I have removed and cleaned the brush but it still won't run due to the error message to clean the brush. The machine has only run 5 or 6 times so brand new machine.
keytkey - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 915
