Einleitung
This guide will allow the user to entirely remove the wheel from the device.
Was du brauchst
Remove the rotary brush simply by grabbing it firmly and pulling it off.
Once you have removed your rotary brush and 4 bolts, you can easy remove the brush guard.
Remove the brush by simply pulling it out.
From there you can clean it or replace the brush with a new one.
Place the robot on its back and remove the six 11mm screws using a Torx T10 screwdriver.
Push the clips, located in the back side, inward.
Gently lift up the top cover until you can see the wires. Then gently un-clip all the wires.
Once you have carefully removed the wire clip; you can fully remove the top cover.
Locate the screws that mount the wheel extension to the Robot.
Unscrew the four 11mm screws indicated with a Torx T10 screwdriver to remove the frame.
Delicately lift up the frame holding the laser. This will access the wheels.
Detach the wheel wires that are connected to the motherboard.
Once the wires are detached, the wheel are free from their casing.
Use a Torx T15 screwdriver to remove the 32.5mm screw.
Finally, just hold and separate the wheel from its axle.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
