Einleitung
This guide will show how to replace the dead, dying, or faulty batteries in your Neato XV-21.
Was du brauchst
Flip the Neato on its back so the bottom is exposed
Unscrew the seven screws.
The Neato's core components are now exposed and ready to be cleaned and/or replaced.
Pinch and pull the white connector to disconnect the battery from the device
Lift and remove the battery from the cavity
3 weitere Nutzer:innen haben diese Anleitung absolviert.
