Einleitung
This guide will help you disassemble your Neato XV-21 and replace the fan.
Was du brauchst
Flip the Neato on its back so the bottom is exposed
Unscrew the seven screws.
The Neato's core components are now exposed and ready to be cleaned and/or replaced.
Pinch and pull the white connector to disconnect the battery from the device
Lift and remove the battery from the cavity
Pinch the white connectors to disconnect the fan from the robot, as previously done with the batteries
Once the wires are disconnected lift the fan from the cavity
Once the fan has been removed you can take a damp cloth and clean the cavity before attaching the new device
3 weitere Personen haben diese Anleitung absolviert.
