Was du brauchst
Flip the Neato on its back so the bottom is exposed
Unscrew the seven screws.
The Neato's core components are now exposed and ready to be cleaned and/or replaced.
Pinch and pull the white connector to disconnect the battery from the device
Lift and remove the battery from the cavity
Remove the 17 visible screws and the 2 covered/hidden screws near the battery compartments that connect the bottom to the top of the Neato robot.
Remove the four screws on the lidar sensor.
After the wires are fully disconnected lift the motor away to reveal the motherboard
Pinch and pull the white connectors indicated in the image, this will allow the top and bottom panels to fully seperate
Pinch and pull the white connectors that connect the LCD screen and motherboard components
Lift motherboard off of the device so that the new motherboard can be connected
Eine weitere Person hat diese Anleitung absolviert.
