Zum Hauptinhalt wechseln
Neato XV-21 Wheels Replacement
Was du brauchst
  1. Neato XV-21 Wheels Replacement, Back Panels of Neato XV-21: Schritt 1, Bild 1 von 1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Wheels Replacement: Schritt 2, Bild 1 von 1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Wheels Replacement: Schritt 3, Bild 1 von 1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Wheels Replacement, Battery: Schritt 4, Bild 1 von 1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
  5. Neato XV-21 Wheels Replacement, Wheels: Schritt 5, Bild 1 von 1
    • Pinch and pull the white connector, indicated in the image, to disconnect the wheel from the robot. Repeat for both wheels
  6. Neato XV-21 Wheels Replacement: Schritt 6, Bild 1 von 1
    • Slide out dowel rod connecting the wheel to the robot.
  7. Neato XV-21 Wheels Replacement: Schritt 7, Bild 1 von 2 Neato XV-21 Wheels Replacement: Schritt 7, Bild 2 von 2
    • Lift the wheel so the spring is exposed
    • Pay particular attention to how the wheel is placed to replicate during reinsertion
    • Unhook the spring from robot
    • Lift the wheel from the cavity
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Needs to Link to Parts List and a way to Order Parts.
Bill Price - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 722
