Einleitung
To replace the wheels you will want your device turned off and have a phillips screwdriver ready. This is a easy fix and should see the problem upon unscrewing the wheels.
Was du brauchst
Flip the Neato on its back so the bottom is exposed
Unscrew the seven screws.
The Neato's core components are now exposed and ready to be cleaned and/or replaced.
Pinch and pull the white connector to disconnect the battery from the device
Lift and remove the battery from the cavity
Pinch and pull the white connector, indicated in the image, to disconnect the wheel from the robot. Repeat for both wheels
Lift the wheel so the spring is exposed
Unhook the spring from robot
Lift the wheel from the cavity
3 weitere Personen haben diese Anleitung absolviert.
