Zum Hauptinhalt wechseln
Neo3Do Audio PCB Replacement
Was du brauchst
    1. Neo3Do Audio PCB Replacement, Back Panel: Schritt 1, Bild 1 von 3 Neo3Do Audio PCB Replacement, Back Panel: Schritt 1, Bild 2 von 3 Neo3Do Audio PCB Replacement, Back Panel: Schritt 1, Bild 3 von 3
      • Turn the Neo3DO face down so that the logo is facing toward you.
      • Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
      Frag FixBot
      Kommentar hinzufügen
    2. Neo3Do Audio PCB Replacement: Schritt 2, Bild 1 von 2 Neo3Do Audio PCB Replacement: Schritt 2, Bild 2 von 2
      • Gently pry the back panel upwards.
      • Ensure the tool does not slip into the device and damage the internals.
      Frag FixBot
    3. Neo3Do Audio PCB Replacement: Schritt 3, Bild 1 von 2 Neo3Do Audio PCB Replacement: Schritt 3, Bild 2 von 2
      • Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
      Frag FixBot
    4. Neo3Do Audio PCB Replacement: Schritt 4, Bild 1 von 1
      • When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
      • The top edge of the device is the edge closest to the camera. The top of the back panel is the side with the hole for the camera.
      Frag FixBot
    1. Neo3Do Audio PCB Replacement, Motherboard: Schritt 5, Bild 1 von 3 Neo3Do Audio PCB Replacement, Motherboard: Schritt 5, Bild 2 von 3 Neo3Do Audio PCB Replacement, Motherboard: Schritt 5, Bild 3 von 3
      • Remove all the tape attached to the motherboard.
      Frag FixBot
    2. Neo3Do Audio PCB Replacement: Schritt 6, Bild 1 von 3 Neo3Do Audio PCB Replacement: Schritt 6, Bild 2 von 3 Neo3Do Audio PCB Replacement: Schritt 6, Bild 3 von 3
      • Pull out the black tabs using the plastic spudger.
      • All sockets that require the same step are marked in the first photo.
      Frag FixBot
    3. Neo3Do Audio PCB Replacement: Schritt 7, Bild 1 von 2 Neo3Do Audio PCB Replacement: Schritt 7, Bild 2 von 2
      • Remove the wire belt from the socket.
      Frag FixBot
    4. Neo3Do Audio PCB Replacement: Schritt 8, Bild 1 von 3 Neo3Do Audio PCB Replacement: Schritt 8, Bild 2 von 3 Neo3Do Audio PCB Replacement: Schritt 8, Bild 3 von 3
      • Lift the black tab and then remove the wire belt.
      Frag FixBot
    5. Neo3Do Audio PCB Replacement: Schritt 9, Bild 1 von 3 Neo3Do Audio PCB Replacement: Schritt 9, Bild 2 von 3 Neo3Do Audio PCB Replacement: Schritt 9, Bild 3 von 3
      Frag FixBot
    6. Neo3Do Audio PCB Replacement: Schritt 10, Bild 1 von 3 Neo3Do Audio PCB Replacement: Schritt 10, Bild 2 von 3 Neo3Do Audio PCB Replacement: Schritt 10, Bild 3 von 3
      • Grip the side of the tab and pull upwards to remove it from the socket.
      • Gripping the wire belt and pulling upwards may cause damage, be sure to avoid it.
      Frag FixBot
    7. Neo3Do Audio PCB Replacement: Schritt 11, Bild 1 von 2 Neo3Do Audio PCB Replacement: Schritt 11, Bild 2 von 2
      • Remove the screws using the J0 head screwdriver.
      • All screws that require the same step are marked in the first photo.
      Frag FixBot
    8. Neo3Do Audio PCB Replacement: Schritt 12, Bild 1 von 3 Neo3Do Audio PCB Replacement: Schritt 12, Bild 2 von 3 Neo3Do Audio PCB Replacement: Schritt 12, Bild 3 von 3
      • Grip the active(red) wire and apply the soldering tool until the solder is soft enough for the wire to be removed.
      • Repeat the same process to remove the neutral(black) wire.
      • All wires that require the same steps are marked in the first photo.
      • The soldering tool is extremely hot, use with caution.
      Frag FixBot
    9. Neo3Do Audio PCB Replacement: Schritt 13, Bild 1 von 3 Neo3Do Audio PCB Replacement: Schritt 13, Bild 2 von 3 Neo3Do Audio PCB Replacement: Schritt 13, Bild 3 von 3
      • Use the flat end of the plastic spudger to remove the motherboard and turn it underside-up.
      Frag FixBot
    10. Neo3Do Audio PCB Replacement: Schritt 14, Bild 1 von 2 Neo3Do Audio PCB Replacement: Schritt 14, Bild 2 von 2
      • Remove the plug from the motherboard socket.
      Frag FixBot
    11. Neo3Do Audio PCB Replacement: Schritt 15, Bild 1 von 3 Neo3Do Audio PCB Replacement: Schritt 15, Bild 2 von 3 Neo3Do Audio PCB Replacement: Schritt 15, Bild 3 von 3
      • Grip the wire and apply the soldering tool until the solder is soft enough for the wire to be removed.
      Frag FixBot
    1. Neo3Do Audio PCB Replacement, Battery & LED screen: Schritt 16, Bild 1 von 2 Neo3Do Audio PCB Replacement, Battery & LED screen: Schritt 16, Bild 2 von 2
      • Remove the screws with a J000 screwdriver
      Frag FixBot
    2. Neo3Do Audio PCB Replacement: Schritt 17, Bild 1 von 2 Neo3Do Audio PCB Replacement: Schritt 17, Bild 2 von 2
      • Use the plastic removal tool to remove the plastic frame.
      Frag FixBot
    3. Neo3Do Audio PCB Replacement: Schritt 18, Bild 1 von 3 Neo3Do Audio PCB Replacement: Schritt 18, Bild 2 von 3 Neo3Do Audio PCB Replacement: Schritt 18, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      • Using the plastic removal tool, lift the LED screen from the battery side, and use the tweezers to help lift the LED screen upwards.
      Frag FixBot
    1. Neo3Do Audio PCB Replacement, Audio PCB: Schritt 19, Bild 1 von 2 Neo3Do Audio PCB Replacement, Audio PCB: Schritt 19, Bild 2 von 2
      • Remove the screws using a Phillips #000 screwdriver.
      Frag FixBot
    2. Neo3Do Audio PCB Replacement: Schritt 20, Bild 1 von 2 Neo3Do Audio PCB Replacement: Schritt 20, Bild 2 von 2
      • Use the plastic removal tool to pry the audio PCB and pull away from the frame to remove it.
      Frag FixBot
Abschluss
USF Tampa, Team 14-3, Eyestone Fall 2016 Mitglied von USF Tampa, Team 14-3, Eyestone Fall 2016
USFT-EYESTONE-F16S14G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 27
Insgesamt: 431
