Zum Hauptinhalt wechseln
Neo3Do Motherboard Replacement
Was du brauchst
  1. Neo3Do Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 3 Neo3Do Motherboard Replacement, Back Panel: Schritt 1, Bild 2 von 3 Neo3Do Motherboard Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Turn the Neo3DO face down so that the logo is facing toward you.
    • Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
    Frag FixBot
    Kommentar hinzufügen
  2. Neo3Do Motherboard Replacement: Schritt 2, Bild 1 von 2 Neo3Do Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Gently pry the back panel upwards.
    • Ensure the tool does not slip into the device and damage the internals.
    Frag FixBot
  3. Neo3Do Motherboard Replacement: Schritt 3, Bild 1 von 2 Neo3Do Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
    Frag FixBot
  4. Neo3Do Motherboard Replacement: Schritt 4, Bild 1 von 1
    • When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
    • The top edge of the device is the edge closest to the camera. The top of the back panel is the side with the hole for the camera.
    Frag FixBot
  5. Neo3Do Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 3 Neo3Do Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 3 Neo3Do Motherboard Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Remove all the tape attached to the motherboard.
    Frag FixBot
  6. Neo3Do Motherboard Replacement: Schritt 6, Bild 1 von 3 Neo3Do Motherboard Replacement: Schritt 6, Bild 2 von 3 Neo3Do Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Pull out the black tabs using the plastic spudger.
    • All sockets that require the same step are marked in the first photo.
    Frag FixBot
  7. Neo3Do Motherboard Replacement: Schritt 7, Bild 1 von 2 Neo3Do Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the wire belt from the socket.
    Frag FixBot
  8. Neo3Do Motherboard Replacement: Schritt 8, Bild 1 von 3 Neo3Do Motherboard Replacement: Schritt 8, Bild 2 von 3 Neo3Do Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Lift the black tab and then remove the wire belt.
    Frag FixBot
  9. Neo3Do Motherboard Replacement: Schritt 9, Bild 1 von 3 Neo3Do Motherboard Replacement: Schritt 9, Bild 2 von 3 Neo3Do Motherboard Replacement: Schritt 9, Bild 3 von 3
    Frag FixBot
  10. Neo3Do Motherboard Replacement: Schritt 10, Bild 1 von 3 Neo3Do Motherboard Replacement: Schritt 10, Bild 2 von 3 Neo3Do Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Grip the side of the tab and pull upwards to remove it from the socket.
    • Gripping the wire belt and pulling upwards may cause damage, be sure to avoid it.
    Frag FixBot
  11. Neo3Do Motherboard Replacement: Schritt 11, Bild 1 von 2 Neo3Do Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Remove the screws using the J0 head screwdriver.
    • All screws that require the same step are marked in the first photo.
    Frag FixBot
  12. Neo3Do Motherboard Replacement: Schritt 12, Bild 1 von 3 Neo3Do Motherboard Replacement: Schritt 12, Bild 2 von 3 Neo3Do Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Grip the active(red) wire and apply the soldering tool until the solder is soft enough for the wire to be removed.
    • Repeat the same process to remove the neutral(black) wire.
    • All wires that require the same steps are marked in the first photo.
    • The soldering tool is extremely hot, use with caution.
    Frag FixBot
  13. Neo3Do Motherboard Replacement: Schritt 13, Bild 1 von 3 Neo3Do Motherboard Replacement: Schritt 13, Bild 2 von 3 Neo3Do Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Use the flat end of the plastic spudger to remove the motherboard and turn it underside-up.
    Frag FixBot
  14. Neo3Do Motherboard Replacement: Schritt 14, Bild 1 von 2 Neo3Do Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Remove the plug from the motherboard socket.
    Frag FixBot
  15. Neo3Do Motherboard Replacement: Schritt 15, Bild 1 von 3 Neo3Do Motherboard Replacement: Schritt 15, Bild 2 von 3 Neo3Do Motherboard Replacement: Schritt 15, Bild 3 von 3
    • Grip the wire and apply the soldering tool until the solder is soft enough for the wire to be removed.
    Frag FixBot
Abschluss
USF Tampa, Team 14-3, Eyestone Fall 2016 Mitglied von USF Tampa, Team 14-3, Eyestone Fall 2016
USFT-EYESTONE-F16S14G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 394
