Einleitung
In this guide you will learn how to replace the large spring located at upper section of the Nerf device. Learning to do so will assist you with trouble shooting problems such as the device not firing darts or a jammed freely moving pump. This problem is usually caused by clogging of foreign objects or darts, within the device, spring malfunction, misaligned pieces.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. After the screws have been removed, gently lift the panel from the gun and set it aside.
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Locate the black cylinder connected to the large spring near the top of the device.
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  5. Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside. Ensure that the small spring connected to the stabilizing piece remains connected.
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
Abschluss
Bradley Penrow
16 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 11-2, Blackwell Fall 2014 Mitglied von USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 4
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 670
