Einleitung
In this guide you will learn how to replace the large spring located at upper section of the Nerf device. Learning to do so will assist you with trouble shooting problems such as the device not firing darts or a jammed freely moving pump. This problem is usually caused by clogging of foreign objects or darts, within the device, spring malfunction, misaligned pieces.
Was du brauchst
Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
After the screws have been removed, gently lift the panel from the gun and set it aside.
Locate the black cylinder connected to the large spring near the top of the device.
Once located, push the black cylinder against the spring and lift it out of the device.
Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
