Einleitung
This easy three step guide will help you find and replace the battery.
Was du brauchst
Using the JIS #1 screwdriver, loosen (without removing) the screw, holding the battery compartment door in place.
Lift the door off the battery compartment.
Remove and replace the batteries, properly discarding the used batteries.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
