Zum Hauptinhalt wechseln
Nerf Dart Tag Swarmfire Motor Spring Replacement
Was du brauchst
  1. Nerf Dart Tag Swarmfire Motor Spring Replacement, Motor Spring Replacement: Schritt 1, Bild 1 von 2 Nerf Dart Tag Swarmfire Motor Spring Replacement, Motor Spring Replacement: Schritt 1, Bild 2 von 2
    • Using the JIS #1 screwdriver, loosen the nine screws, holding the outer yellow shell in place
    • The screwdriver you'll be using is a J1 head from the 64 Bit Kit.
    • Be sure to sure to use the Magnetic Project Mat to prevent loss of the screws.
  2. Nerf Dart Tag Swarmfire Motor Spring Replacement: Schritt 2, Bild 1 von 1
    • Lift off the outer yellow shell.
  3. Nerf Dart Tag Swarmfire Motor Spring Replacement: Schritt 3, Bild 1 von 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: Schritt 3, Bild 2 von 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: Schritt 3, Bild 3 von 3
    • Remove the screw holding the battery compartment shut.
    • Lift off the inner blue casing
  4. Nerf Dart Tag Swarmfire Motor Spring Replacement: Schritt 4, Bild 1 von 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: Schritt 4, Bild 2 von 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: Schritt 4, Bild 3 von 3
    • Lift off the blue casing, exposing the white motor spring compartment.
    • Loosen and remove the three screws holding the white compartment door shut.
  5. Nerf Dart Tag Swarmfire Motor Spring Replacement: Schritt 5, Bild 1 von 2 Nerf Dart Tag Swarmfire Motor Spring Replacement: Schritt 5, Bild 2 von 2
    • Unsnap the white compartment into two pieces.
  6. Nerf Dart Tag Swarmfire Motor Spring Replacement: Schritt 6, Bild 1 von 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: Schritt 6, Bild 2 von 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: Schritt 6, Bild 3 von 3
    • Remove the motor spring located inside the rotating barrel and replace.
Abschluss
Sonal Purohit
115 Reputation
1 Anleitung geschrieben
University of Memphis, Team 2-3, Kim SU 2016 Mitglied von University of Memphis, Team 2-3, Kim SU 2016
UM-KIM-SU16S2G3
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 872
