Einleitung
The device is accompanied with a flashlight in order to be used effectively in the dark. The light will only turn on if using the proper batteries. This guide will show you how to remove the batteries from their compartment and properly place in three Triple A batteries. Following these steps will allow the flashlight to function properly.
Was du brauchst
The lid that covers the batteries should then rise up slightly, allowing it to be pulled off.
2 weitere Personen haben diese Anleitung absolviert.
