Zum Hauptinhalt wechseln
Nerf N-Strike Deploy CS-6 Dart Tooth Replacement
Was du brauchst
  1. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement, Dart Tooth: Schritt 1, Bild 1 von 1
    • Before releasing the device in Stealth mode, take out hidden screws as shown
    • Extend the device in Stealth Mode by pressing the button found on the handle.
  2. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: Schritt 2, Bild 1 von 3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: Schritt 2, Bild 2 von 3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: Schritt 2, Bild 3 von 3
    • Take out the screws from the pump.
    • Proceed to take out the other screws from the device to take off the cover.
    • For the pump, the screw's length extends out to 1.9 cm. The majority size of the screws extend out to 1.3 cm.
  3. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: Schritt 3, Bild 1 von 2 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: Schritt 3, Bild 2 von 2
    • Once the screws are out, you are able to take the cover piece off.
    • Proceed to remove the screws
    • Taking off those screws are vital in replacing the dart tooth.
  4. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: Schritt 4, Bild 1 von 1
    • Carefully place cover piece above the device.
  5. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: Schritt 5, Bild 1 von 1
    • Unscrew as shown to aid in the replacement.
  6. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: Schritt 6, Bild 1 von 1
    • To take out the dart tooth, push the spring to the left.
    • The dart tooth should pop out with ease.
  7. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: Schritt 7, Bild 1 von 1
    • Once pulled away from the device, take off the orange piece connected to the darth tooth
    • The piece can be identified with the spring.
  8. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: Schritt 8, Bild 1 von 1
    • You should now be able to pull apart the dart tooth from the device.
    • The piece that has been pulled away will have a type of lubrication. If this piece requires replacement, it will slide on with ease.
  9. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: Schritt 9, Bild 1 von 1
    • Make any adjustment to the dart tooth as seen. May be pulled either up or down.
    • Place in the replacing piece in order to fix the darth tooth
  10. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: Schritt 10, Bild 1 von 3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: Schritt 10, Bild 2 von 3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: Schritt 10, Bild 3 von 3
    • Place back on the orange piece with the spring to its original spot on the dart tooth.
    • While setting in the dart tooth back into place, the small spring on the yellow piece must be placed in its compartment as shown.
    • Place back cover pieces in order to secure the screws back into place.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 2,950
