Einleitung
When users prefer to use the flashlight from the device, can be the complication that the lens is damaged. Obscuring the lens can alter the lights focus on other objects. In this guide, we will show you how to properly disassemble your device to access the lens. Upon doing so, you will then be able to dispose the damaged lens and put in the replacement lens.
Was du brauchst
Proceed to take out the hidden screws when the device is collapsed.
Once the hidden screws are out, extend your device in stealth mode.
Once the device is extended out, proceed to take out the necessary screws as shown.
Once all the necessary screws are taken off, the interior of your device should be visible.
Unscrew the orange barrel located in front of your device.
Now that the cover is off and the screws are out, pry off the barrel of the device.
Once the orange barrel of the device has been pried off, proceed to take the metal clip off from where it is currently located.
As shown, use your Phillips #0 head screwdriver to unscrew the highlighted areas
Once all the screws have been removed, the cover for the light-bulb is able to come off.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
