Einleitung
The internal spring mechanism is what helps fire the darts from the device. A damaged internal spring can cause difficulty in firing and ultimately decrease the performance. This guide will show you step-by-step on how to pull apart the cover piece of the device to access the internal spring. Upon doing so, you will be shown how to properly place in a new spring to effectively increase the device's performance.
Was du brauchst
Removal of the pump is needed in order to get to the spring mechanism.
Locate the screws on the orange pump and proceed to take them out.
Top extension part can now be taken off.
Once pulled apart, this is how the device should look.
Locate your damage spring mechanism.
Once located, you may now pull it away from the device.
Place device cover back on.
When trying to close the cover back on top, push spring from the left towards the right to adjust cover in place.
Eine weitere Person hat diese Anleitung absolviert.
