Zum Hauptinhalt wechseln
Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement
Was du brauchst
  1. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: Schritt 1, Bild 1 von 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: Schritt 1, Bild 2 von 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: Schritt 1, Bild 3 von 3
    • Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
    • Pull off the orange cap.
  2. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: Schritt 2, Bild 1 von 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: Schritt 2, Bild 2 von 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: Schritt 2, Bild 3 von 3
    • With the rifle barrel pointing left, remove the two 8 mm phillips screws holding the slide mechanism together.
    • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
    • Separate and remove the two halves of the slide mechanism.
    • Make sure to keep track of which screws correspond to which holes.
  3. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: Schritt 3, Bild 1 von 2 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: Schritt 3, Bild 2 von 2
    • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
    • Remove the two 5 mm phillips screws from the main body.
    • Remove the two 8 mm phillips screws from the main body.
    • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
  4. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: Schritt 4, Bild 1 von 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: Schritt 4, Bild 2 von 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: Schritt 4, Bild 3 von 3
    • Pull the two halves of the rifle apart.
    • Be careful of the spring at the rear end of the rifle. It may come flying out.
    • If you have difficulty pulling the two halves apart, use a spudger to gently pry the edges of the body apart.
    • Also be careful of small parts when opening the gun, they may be easy to lose.
    • Remove the access gate and barrel cover.
  5. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: Schritt 5, Bild 1 von 2 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 5mm phillips screws from the rifle muzzle.
  6. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: Schritt 6, Bild 1 von 1
    • Remove the muzzle and barrel from the rifle body.
  7. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: Schritt 7, Bild 1 von 1
    • Separate the muzzle from the barrel.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 10-35, Maness Winter 2014 Mitglied von Cal Poly, Team 10-35, Maness Winter 2014
CPSU-MANESS-W14S10G35
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 5,835
