Zum Hauptinhalt wechseln
Nerf N-Strike Elite Retaliator Barrel Replacement
Was du brauchst
  1. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel: Schritt 1, Bild 1 von 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Grip: Schritt 2, Bild 1 von 1
    • Slide the hand grip assembly toward the end of the barrel and off the barrel assembly.
    • This may require more force than anticipated.
  3. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel Cap: Schritt 3, Bild 1 von 1
    • Disassemble the orange barrel cap by removing two 8mm Phillips screws.
  4. Nerf N-Strike Elite Retaliator  Barrel Replacement, Disassemble Barrel Assembly: Schritt 4, Bild 1 von 1
    • Disassemble the barrel assembly by removing four 8mm Phillips screws from the blue barrel housing.
    • There are springs that may become displaced when the barrel housing is removed. Proceed with caution.
  5. Nerf N-Strike Elite Retaliator  Barrel Replacement, Replace Barrel: Schritt 5, Bild 1 von 1
    • Remove the orange barrel from the assembly.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
ericharman
1.422 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 21
Insgesamt: 11,766
