Einleitung
A fatigued spring can be detrimental to your blaster’s performance. This guide shows how to disassemble the blaster to replace this component. There many small components such as screws and springs that will be removed in this procedure. Be sure to record their locations for easy reassembly.
Was du brauchst
While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
Remove the stock attachment point by removing the two 8mm Phillips head screws.
Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
While holding down the white Plunger tube, pull the spring backwards to remove it from the blaster.
11 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
how do I remove the screws that you have to pull back the sliding mechanism if it cant be pulled back
