Zum Hauptinhalt wechseln
Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement
Was du brauchst
  1. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: Schritt 1, Bild 1 von 2 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: Schritt 1, Bild 2 von 2
    • Remove three screws with a Phillips #1 screwdriver.
    • Remove the pump grip.
  2. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: Schritt 2, Bild 1 von 1
    • Remove thirteen highlighted screws using a Phillips #1 screwdriver.
    • The top rail has shorter screws than the rest.
    • Some of these are captive screws and cannot be removed.
  3. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: Schritt 3, Bild 1 von 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: Schritt 3, Bild 2 von 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: Schritt 3, Bild 3 von 3
    • Remove the backside by sliding the plastic spudger across the seam.
    • There are loose parts that can fall out. Take these off and put them aside.
  4. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: Schritt 4, Bild 1 von 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: Schritt 4, Bild 2 von 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: Schritt 4, Bild 3 von 3
    • Separate the trigger mechanism from the barrel.
  5. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: Schritt 5, Bild 1 von 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: Schritt 5, Bild 2 von 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: Schritt 5, Bild 3 von 3
    • Remove the plunger springs from the mechanism by pulling one of the springs back then bending it off the connection.
    • These are tricky to remove, so be careful when pulling them off.
  6. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: Schritt 6, Bild 1 von 2 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: Schritt 6, Bild 2 von 2
    • Now pull the springs out and add new ones.
    • There are a few pieces with springs that can misalign in reassembly. Keep in mind where they are.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 91
Insgesamt: 3,451
