Zum Hauptinhalt wechseln
Nerf N-Strike Firestrike Laser Trigger Replacement
Was du brauchst
  1. Nerf N-Strike Firestrike Laser Trigger Replacement, Remove battery cover: Schritt 1, Bild 1 von 1
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike Laser Trigger Replacement: Schritt 2, Bild 1 von 2 Nerf N-Strike Firestrike Laser Trigger Replacement: Schritt 2, Bild 2 von 2
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike Laser Trigger Replacement, Blaster Casing: Schritt 3, Bild 1 von 1
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike Laser Trigger Replacement: Schritt 4, Bild 1 von 2 Nerf N-Strike Firestrike Laser Trigger Replacement: Schritt 4, Bild 2 von 2
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike Laser Trigger Replacement: Schritt 5, Bild 1 von 2 Nerf N-Strike Firestrike Laser Trigger Replacement: Schritt 5, Bild 2 von 2
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike Laser Trigger Replacement, Laser Trigger: Schritt 6, Bild 1 von 2 Nerf N-Strike Firestrike Laser Trigger Replacement, Laser Trigger: Schritt 6, Bild 2 von 2
    • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
Abschluss
Jong Wan Kim
461 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 15-6, Amido Spring 2015 Mitglied von Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 1,679
