Einleitung
Firing too many bullets at once? Use this guide to fix a jammed trigger on your Nerf N-Strike Maverick.
Was du brauchst
Remove the 10 screws on the outer shell of the Maverick.
Check the inner chassis around the trigger area. Make sure the springs and parts can move freely.
After examining and fixing the chassis, screw the trigger back onto the body.
Hook the upper spring to the metal rod.
Replace the outer shell of the Maverick and the top left screw.
Screw the top left piece back onto the Maverick.
Replace the 10 screws on the Maverick.
2 weitere Personen haben diese Anleitung absolviert.
