Einleitung
In two steps, this guide will show you how to remove the slide pieces with a screwdriver so that they can be replaced.
Was du brauchst
Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
2 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Ok so the slide is removed now what? It's still stuck
i was thinking the same thing
