Einleitung
There are some instances when the spring which allows a person to fire a Nerf crossbow breaks. One you have opened up the Nerf crossbow you will be able to tell whether or not the spring has broken. If in fact you are dealing with a broken swing then you are in luck since it can be replaced.
Was du brauchst
Now that the spring has been reattached to the trigger repeat step two.
Finish by performing steps two and three in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
how do you get the arms/wings off without damaging the lock on clip?
