Einleitung
If your Nest Cam IQ has lost clear viability, you most likely have a cracked lens, which Requires replacement.
A functional lens provides a clear view. If you notice poor quality or lines when pulling up Nest Cam IQ recordings, consider changing out your lens.
Was du brauchst
To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
Leave the Opener on the glass lens for two minutes.
Place a suction cup on the glass lens that you heated up with the iOpener.
Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
Pull off the glass lens using the suction cup.
2 weitere Personen haben diese Anleitung absolviert.
