Einleitung
If your Nest Cam IQ motherboard is overheating or shutting down, it requires replacement.
A functional motherboard connects all of your hardware. If you notice a burning smell coming from the motherboard or if the motherboard is off completely, consider changing out your motherboard.
Was du brauchst
To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
Leave the Opener on the glass lens for two minutes.
Place a suction cup on the glass lens that you heated up with the iOpener.
Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
Pull off the glass lens using the suction cup.
Carefully disconnect the flat black ribbon cable connecting the metal plate to the LED.
Remove the metal plate.
Remove the five 9 mm TR6 Torx screws from the LED cover.
Pull off the LED cover.
Carefully disconnect the flat black ribbon cable connecting the LED to the motherboard.
Remove the LED cover.
Remove the two 7 mm TR6 Torx screws securing the camera.
Carefully pull out the camera.
Carefully disconnect the flat black ribbon cable connecting the camera to the motherboard.
Remove the camera.
Remove the three 19 mm TR6 Torx screws from the camera holder.
Carefully lift the tab up and away from the camera holder.
Remove the camera holder.
Remove the one 4 mm TR6 Torx screw from the clear cover.
Remove the clear cover.
Remove the four 11 mm TR6 Torx screws from the clamp securing the mounting stand.
Remove the clamp.
Carefully pull away the cables connecting the mounting stand to the body.
Carefully remove the mounting stand.
Remove the three 9 mm TR6 Torx connecting the motherboard and speaker to the body.
Pull the motherboard and speaker from the body.
Remove the one 8 mm TR6 Torx screws securing the speaker to the motherboard.
Remove the two 4 mm TR6 Torx screws securing the speaker to the motherboard.
Carefully pull away the speaker.
Carefully disconnect the cable connecting the speaker to the motherboard.
Remove the four 4 mm TR6 Torx screws securing the motherboard.
Remove the two 5 mm 3.5 low-head socket cap screws securing the motherboard.
Remove the motherboard.
