Zum Hauptinhalt wechseln
Nest Cam IQ Mounting Stand Replacement
Was du brauchst
  1. Nest Cam IQ Mounting Stand Replacement, Mounting Stand: Schritt 1, Bild 1 von 1
    • To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
    • Leave the Opener on the glass lens for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the Opener, use the iOpener Instructions Guide.
  2. Nest Cam IQ Mounting Stand Replacement: Schritt 2, Bild 1 von 1
    • Use an opening tool to split apart the glass lens from the body.
    • Be careful to not break the glass when prying from the body.
  3. Nest Cam IQ Mounting Stand Replacement: Schritt 3, Bild 1 von 1
    • Place a suction cup on the glass lens that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
    • Pull off the glass lens using the suction cup.
  4. Nest Cam IQ Mounting Stand Replacement: Schritt 4, Bild 1 von 2 Nest Cam IQ Mounting Stand Replacement: Schritt 4, Bild 2 von 2
    • Carefully disconnect the flat black ribbon cable connecting the metal plate to the LED.
    • Remove the metal plate.
  5. Nest Cam IQ Mounting Stand Replacement: Schritt 5, Bild 1 von 2 Nest Cam IQ Mounting Stand Replacement: Schritt 5, Bild 2 von 2
    • Remove the five 9mm TR6 Torx screws from the LED cover.
    • Pull off the LED cover.
    • As you remove the LED cover, be careful not to tear the flat black ribbon connecting the LED to the motherboard.
  6. Nest Cam IQ Mounting Stand Replacement: Schritt 6, Bild 1 von 3 Nest Cam IQ Mounting Stand Replacement: Schritt 6, Bild 2 von 3 Nest Cam IQ Mounting Stand Replacement: Schritt 6, Bild 3 von 3
    • Carefully disconnect the flat black ribbon cable connecting the LED to the motherboard.
    • Remove the LED cover.
  7. Nest Cam IQ Mounting Stand Replacement: Schritt 7, Bild 1 von 1
    • Remove the two 7mm TR6 Torx screws securing the camera.
    • Carefully pull out the camera.
    • As you remove the camera, be careful not to tear the flat black ribbon connecting the camera to the motherboard.
  8. Nest Cam IQ Mounting Stand Replacement: Schritt 8, Bild 1 von 2 Nest Cam IQ Mounting Stand Replacement: Schritt 8, Bild 2 von 2
    • Carefully disconnect the flat black ribbon cable connecting the camera to the motherboard.
    • Remove the camera.
  9. Nest Cam IQ Mounting Stand Replacement: Schritt 9, Bild 1 von 3 Nest Cam IQ Mounting Stand Replacement: Schritt 9, Bild 2 von 3 Nest Cam IQ Mounting Stand Replacement: Schritt 9, Bild 3 von 3
    • Remove the three 19mm TR6 Torx screws from the camera holder.
    • Carefully lift the tab up and away from the camera holder.
    • Remove the camera holder.
  10. Nest Cam IQ Mounting Stand Replacement: Schritt 10, Bild 1 von 2 Nest Cam IQ Mounting Stand Replacement: Schritt 10, Bild 2 von 2
    • Remove the one 4mm TR6 Torx screw from the clear cover.
    • Remove the clear cover.
  11. Nest Cam IQ Mounting Stand Replacement: Schritt 11, Bild 1 von 3 Nest Cam IQ Mounting Stand Replacement: Schritt 11, Bild 2 von 3 Nest Cam IQ Mounting Stand Replacement: Schritt 11, Bild 3 von 3
    • Remove the four 11mm TR6 Torx screws from the clamp securing the mounting stand.
    • Remove the clamp.
    • Carefully pull away the cables connecting the mounting stand to the body.
  12. Nest Cam IQ Mounting Stand Replacement: Schritt 12, Bild 1 von 1
    • Carefully remove the mounting stand.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jas Ownby
806 Reputation
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 20
Insgesamt: 270
