Einleitung
The Nest Cam also has a listening function. The mic cable is responsible for sound intake. If your Nest Cam's sound is either not transmitting or muffled or even indistinguishable, the mic cable may need to be replaced.
Was du brauchst
Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
Holding the back panel firmly, use a spudger to pry off the small plastic panel holding the mic cable in place.
Use a heat gun to melt the glue keeping the mic cable in place and then remove it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
3 Kommentare
Thank you for this look inside the device. In the Nest settings there is a way to turn off the microphone, but anyone with access can turn it back on. I'm going to use this guide to unplug the microphone and permanently (but reversibly) disable it.
