Zum Hauptinhalt wechseln
Nest Cam Motherboard Replacement
Was du brauchst
  1. Nest Cam Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Remove the four 6 mm screws from the back panel with the JIS 000 screwdriver.
    • We suggest designated areas to keep track of all screws.
    Frag FixBot
    Kommentar hinzufügen
  2. Nest Cam Motherboard Replacement: Schritt 2, Bild 1 von 3 Nest Cam Motherboard Replacement: Schritt 2, Bild 2 von 3 Nest Cam Motherboard Replacement: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
    Frag FixBot
  3. Nest Cam Motherboard Replacement: Schritt 3, Bild 1 von 2 Nest Cam Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 4 mm screws with the JIS 000 screwdriver from the center.
    • Disconnect the black Wi-Fi cable from the motherboard with the tweezers.
    Frag FixBot
  4. Nest Cam Motherboard Replacement: Schritt 4, Bild 1 von 3 Nest Cam Motherboard Replacement: Schritt 4, Bild 2 von 3 Nest Cam Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic spudger to lift the motherboard slightly up to expose and disconnect the white cable and the yellow/white IR cable with tweezers.
    • Then use the spudger or a finger to lift the motherboard completely up and off.
    • When installing the new motherboard ensure that all wires are reconnected before securing.
    Frag FixBot
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 1-1, Leahy Spring 2016 Mitglied von USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Mitglieder
10 Anleitungen geschrieben
4 Kommentare zur Anleitung
where can I get a MoBo for my drop cam?
mikelebp1 - Antwort Teilen
where can i find a motherboard replacement?
Steve - Antwort Teilen
I have a Nest Outdoor IQ Camera. The Camera is Dead. Would love to Replace the Motherboard. Where can I get one ???
pmwenc@aol.com - Antwort Teilen
same here, no where to be found online
chantalder - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 65
Insgesamt: 25,591
