Zum Hauptinhalt wechseln
Nest Cam Outdoor S Battery Replacement
Was du brauchst
  1. Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: Schritt 1, Bild 1 von 2 Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: Schritt 1, Bild 2 von 2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Battery Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Battery Replacement: Schritt 4, Bild 1 von 2 Nest Cam Outdoor S Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Battery Replacement, Battery: Schritt 5, Bild 1 von 2 Nest Cam Outdoor S Battery Replacement, Battery: Schritt 5, Bild 2 von 2
    • Wedge a nylon spudger between the white outer shell and the battery.
    • Slowly pull the battery away from the plastic camera cover.
    • The battery is only held on with glue.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 Mitglied von UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G6
2 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
Do you have the P/N of the battery??
Richard K Yabuki - Antwort
Where to buy a replacement battery?
Ted McKenna - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 36
Letzte 30 Tage: 228
Insgesamt: 6,542
