Zum Hauptinhalt wechseln
Nest Cam Outdoor S Internal Camera Replacement
Was du brauchst
  1. Nest Cam Outdoor S Internal Camera Replacement, Plastic Camera Cover: Schritt 1, Bild 1 von 2 Nest Cam Outdoor S Internal Camera Replacement, Plastic Camera Cover: Schritt 1, Bild 2 von 2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Internal Camera Replacement: Schritt 2, Bild 1 von 1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Internal Camera Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Internal Camera Replacement: Schritt 4, Bild 1 von 2 Nest Cam Outdoor S Internal Camera Replacement: Schritt 4, Bild 2 von 2
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Internal Camera Replacement, Internal Camera: Schritt 5, Bild 1 von 1
    • Pry the plastic cover away from the motherboard at the plastic clips using a spudger.
  6. Nest Cam Outdoor S Internal Camera Replacement: Schritt 6, Bild 1 von 1
    • Remove the four mounting screws from the motherboard.
  7. Nest Cam Outdoor S Internal Camera Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the yellow camera cable from the motherboard.
    • Remove the camera from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Skylar DeVoe
235 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 Mitglied von UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G6
2 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
Can you replace the corn to the actual camera
Cathy Willis - Antwort
Can you replace the corn to actual camera
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 33
Insgesamt: 1,664
