Was du brauchst
Wedge a spudger between the black front panel and the white outer shell.
Slide the spudger around the edge of the panel to pop it off.
Disconnect the microphone cable to separate the motherboard from the main camera unit.
Pry the plastic cover away from the motherboard at the plastic clips using a spudger.
Disconnect the yellow camera cable from the motherboard.
Remove the motherboard from the device.
