Zum Hauptinhalt wechseln
Nest Cam Side Snap Locks Replacement
Was du brauchst
  1. Nest Cam Side Snap Locks Replacement, Side Snap Locks: Schritt 1, Bild 1 von 1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Side Snap Locks Replacement: Schritt 2, Bild 1 von 3 Nest Cam Side Snap Locks Replacement: Schritt 2, Bild 2 von 3 Nest Cam Side Snap Locks Replacement: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Side Snap Locks Replacement: Schritt 3, Bild 1 von 3 Nest Cam Side Snap Locks Replacement: Schritt 3, Bild 2 von 3 Nest Cam Side Snap Locks Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
  4. Nest Cam Side Snap Locks Replacement: Schritt 4, Bild 1 von 2 Nest Cam Side Snap Locks Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 3 mm Phillips #J000 screws from the side snap locks. Remove the old side snap locks and place the new side snap locks.
    • Make sure everything lines up for the screws.
Abschluss
USF Tampa, Team 1-1, Leahy Spring 2016 Mitglied von USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 1,994
