Zum Hauptinhalt wechseln
Nest Cam Speaker Replacement
Was du brauchst
  1. Nest Cam Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Speaker Replacement: Schritt 2, Bild 1 von 1
    • Open the back panel completely to expose the speaker indicated by the red circle.
  3. Nest Cam Speaker Replacement: Schritt 3, Bild 1 von 3 Nest Cam Speaker Replacement: Schritt 3, Bild 2 von 3 Nest Cam Speaker Replacement: Schritt 3, Bild 3 von 3
    • Remove old speaker gently with a spudger.
    • When placing the new speaker in make sure the prongs are facing the right direction and will connect with the two connector points on the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jade Weiss
662 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 1-1, Leahy Spring 2016 Mitglied von USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Mitglieder
10 Anleitungen geschrieben
4 Kommentare
where can I buy the new replacement speaker part?
Bradley Kang - Antwort
Anyone find out the answer to Bradley's question?
Ravi - Antwort
I’m curious as well if anyone has found where to obtain replacement/repair parts. Should be simple enough if we can determine the part number of the speaker.. suppose I’ll tear one down real quick to see.
Christopher Monge - Antwort
Looking at the speaker without thermal coverings looks like it just has some sound information. “8 ohm 0.5 w”. Next line, “1742 (space) 1”. Third line, “+ S -”.
Looks like electrical info of the speaker. I’ll keep looking!
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 2,678
