Zum Hauptinhalt wechseln
Nest Dropcam Pro Camera Lens Replacement
Was du brauchst
  1. Nest Dropcam Pro Camera Lens Replacement, Outer Case: Schritt 1, Bild 1 von 1
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
    Frag FixBot
    Kommentar hinzufügen
  2. Nest Dropcam Pro Camera Lens Replacement: Schritt 2, Bild 1 von 2 Nest Dropcam Pro Camera Lens Replacement: Schritt 2, Bild 2 von 2
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
    Frag FixBot
  3. Nest Dropcam Pro Camera Lens Replacement: Schritt 3, Bild 1 von 2 Nest Dropcam Pro Camera Lens Replacement: Schritt 3, Bild 2 von 2
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
    Frag FixBot
  4. Nest Dropcam Pro Camera Lens Replacement, Motherboard: Schritt 4, Bild 1 von 2 Nest Dropcam Pro Camera Lens Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
    Frag FixBot
  5. Nest Dropcam Pro Camera Lens Replacement: Schritt 5, Bild 1 von 2 Nest Dropcam Pro Camera Lens Replacement: Schritt 5, Bild 2 von 2
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
    Frag FixBot
  6. Nest Dropcam Pro Camera Lens Replacement: Schritt 6, Bild 1 von 2 Nest Dropcam Pro Camera Lens Replacement: Schritt 6, Bild 2 von 2
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
    Frag FixBot
  7. Nest Dropcam Pro Camera Lens Replacement: Schritt 7, Bild 1 von 2 Nest Dropcam Pro Camera Lens Replacement: Schritt 7, Bild 2 von 2
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
    Frag FixBot
  8. Nest Dropcam Pro Camera Lens Replacement, Camera Lens: Schritt 8, Bild 1 von 2 Nest Dropcam Pro Camera Lens Replacement, Camera Lens: Schritt 8, Bild 2 von 2
    Frag FixBot
  9. Nest Dropcam Pro Camera Lens Replacement: Schritt 9, Bild 1 von 3 Nest Dropcam Pro Camera Lens Replacement: Schritt 9, Bild 2 von 3 Nest Dropcam Pro Camera Lens Replacement: Schritt 9, Bild 3 von 3
    • Peel off the paper seal holding the Lens and LEDs together.
    • Disconnect the red and white wire from the bottom board.
    Frag FixBot
  10. Nest Dropcam Pro Camera Lens Replacement: Schritt 10, Bild 1 von 2 Nest Dropcam Pro Camera Lens Replacement: Schritt 10, Bild 2 von 2
    • Lift up the foam cover to reveal a second screw underneath.
    • Using a Philips #0 screwdriver, remove the two 3 mm screws.
    Frag FixBot
  11. Nest Dropcam Pro Camera Lens Replacement: Schritt 11, Bild 1 von 1
    • With the screws gone, lift the camera lens away from the remaining components.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 15-4, Blackwell Fall 2015 Mitglied von USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 Mitglieder
12 Anleitungen geschrieben
2 Kommentare zur Anleitung
Where do you get replacement lens?
Jim Fischer - Antwort Teilen
good morning , is there any store on the USA where i can send my drop camera ti get fix? it fell and doesn't want to broadcast any image.
andres - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 32
Insgesamt: 4,302
