Zum Hauptinhalt wechseln
Nest Dropcam Pro Micro-USB Port Replacement
Was du brauchst
  1. Nest Dropcam Pro Micro-USB Port Replacement, Outer Case: Schritt 1, Bild 1 von 1
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Micro-USB Port Replacement: Schritt 2, Bild 1 von 2 Nest Dropcam Pro Micro-USB Port Replacement: Schritt 2, Bild 2 von 2
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Micro-USB Port Replacement: Schritt 3, Bild 1 von 2 Nest Dropcam Pro Micro-USB Port Replacement: Schritt 3, Bild 2 von 2
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Micro-USB Port Replacement, Motherboard: Schritt 4, Bild 1 von 2 Nest Dropcam Pro Micro-USB Port Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Micro-USB Port Replacement: Schritt 5, Bild 1 von 2 Nest Dropcam Pro Micro-USB Port Replacement: Schritt 5, Bild 2 von 2
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Nest Dropcam Pro Micro-USB Port Replacement: Schritt 6, Bild 1 von 2 Nest Dropcam Pro Micro-USB Port Replacement: Schritt 6, Bild 2 von 2
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Micro-USB Port Replacement: Schritt 7, Bild 1 von 2 Nest Dropcam Pro Micro-USB Port Replacement: Schritt 7, Bild 2 von 2
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Nest Dropcam Pro Micro-USB Port Replacement, Micro-USB Port: Schritt 8, Bild 1 von 2 Nest Dropcam Pro Micro-USB Port Replacement, Micro-USB Port: Schritt 8, Bild 2 von 2
    • Using a soldering station and desoldering braid, desolder the four points surrounding the Micro-USB port.
    • Lift the Micro-USB port away from the motherboard.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
David Foens
893 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 15-4, Blackwell Fall 2015 Mitglied von USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 Mitglieder
12 Anleitungen geschrieben
4 Kommentare
I don't have the soldering tools but I used lazerbond to reattach the old port. I hope all the conductors are touching their counter parts. I haven't plugged it back in yet. Wish me luck.
Kreschendalyn Backus - Antwort
Did it work for you?
Michael Candy -
Where can you order the micro-usb charge port for this cam?
Danny Acevedo - Antwort
Not sure where you get them but according to one site it uses a Micro USB 2.0 Type B Receptacle.
https://bit.ly/2Kg01z6
Debbie - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 5,648
