Einleitung
This guide will show how to remove the faceplate and casing from the Nest Hello.
Was du brauchst
Insert the pick between the black faceplate and white casing of the Nest Hello.
Pry the faceplate away from the device with the opening pick.
Completely remove the faceplate from the device, do not be afraid to pull hard.
Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
Insert opening pick between the white casing and the black internal circuitry and pry it out.
2 Kommentare
Are Replacement parts available anywhere? Can’t seem to find anything… thanks!
