Einleitung
This guide will help you replace a leaky O-Ring caused by exposure to the elements or damage during disassembly. All you will need to access this are iFixit opening picks. It is recommended that this is replaced anytime the device is opened as it can be pinched or torn during removal of the face plate or device housing.
Was du brauchst
Insert the pick between the black faceplate and white casing of the Nest Hello.
Pry the faceplate away from the device with the opening pick.
Completely remove the faceplate from the device, do not be afraid to pull hard.
Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
Insert opening pick between the white casing and the black internal circuitry and pry it out.
Remove the O-Ring (colored blue) from the device. It is placed around the edge of the motherboard.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Is there a link available for spare replacement parts? I can’t seem to find anything other than replacement internal batteries . Thanks!
