Einleitung
Replacing the battery on your Nest couldn't be easier. The only tools required are tweezers, a Phillips #0 screwdriver, Phillips #2 screwdriver, and the opening tool
Was du brauchst
Grasp the display's outer ring with your fingers and pull directly away while rotating clockwise to remove the thermostat from the wall.
Go to the electrical panel and turn off the circuit to make sure no power is running to the thermostat.
Once the power is off, disconnect the Y1, G, R, W1, C, and OB wires.
Remove the two 1 ¼” drywall screws holding the base display and base plate in the wall using a Phillips #2 screwdriver.
Remove the base plate and base display.
Grab the pin connector and gently pull up to remove the thermostat backplate from the thermostat.
Grasp the orange tab with tweezers and gently pull the ribbon cable directly away from the motherboard.
Disconnect the battery connection identifiable by the black, yellow, and red wire.
Pull down the two pull tabs on the battery.
Grasp the battery with your fingers.
Pull gently directly away from the display to unplug the battery from the display motherboard.
