Zum Hauptinhalt wechseln
Nest Thermostat E Motherboard Replacement
Was du brauchst
  1. Nest Thermostat E Motherboard Replacement, Base Plate: Schritt 1, Bild 1 von 1
    • Grasp the display's outer ring with your fingers and pull directly away while rotating clockwise to remove the thermostat from the wall.
    • Go to the electrical panel and turn off the circuit to make sure no power is running to the thermostat.
    • Once the power is off, disconnect the Y1, G, R, W1, C, and OB wires.
    • Remember the placement of each wire for reassembly.
  2. Nest Thermostat E Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 1 ¼” drywall screws holding the base display and base plate in the wall using a Phillips #2 screwdriver.
    • Remove the base plate and base display.
  3. Nest Thermostat E Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Pry the base display off of the baseplate using an iFixit opening tool.
  4. Nest Thermostat E Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Remove the four 6 mm screws using a Phillips #0 screwdriver.
    • The two smaller screws go around the pin connector and the two larger screws go by the outside bezel.
    • Grab the pin connector and pull up to remove the thermostat backplate from the thermostat.
  5. Nest Thermostat E Motherboard Replacement: Schritt 5, Bild 1 von 2 Nest Thermostat E Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Flip the base display over and the display motherboard will remove itself from the display.
Abschluss
Andrew Ahlborn
368 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 17
Insgesamt: 213
