Zum Hauptinhalt wechseln
Nest x Yale Lock Motherboard Replacement
Was du brauchst
  1. Nest x Yale Lock Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Before proceeding, make sure the batteries are removed to avoid being electrocuted and damage to the lock
    • If you do not know how to remove the batteries then I would recommend looking at our battery replacement guide for help.
    Frag FixBot
    Kommentar hinzufügen
  2. Nest x Yale Lock Motherboard Replacement: Schritt 2, Bild 1 von 2 Nest x Yale Lock Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove 3 screws as shown to remove the first cover.
    • The 3 screws are 0.25 inches length
    Frag FixBot
  3. Nest x Yale Lock Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Using a pin to push down the knot holding the wire and the tweezer to safely remove the wire from the motherboard
    Frag FixBot
  4. Nest x Yale Lock Motherboard Replacement: Schritt 4, Bild 1 von 2 Nest x Yale Lock Motherboard Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use a spudger or plastic tool to lift the ZIF lock upward (as shown in the first picture).
    • Use tweezers to remove the ribbon cable from the motherboard.
    Frag FixBot
  5. Nest x Yale Lock Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Continue to remove 2 screws holding the motherboard to the lock shell.
    • The screws are 0.20 inches in length.
    Frag FixBot
  6. Nest x Yale Lock Motherboard Replacement: Schritt 6, Bild 1 von 2 Nest x Yale Lock Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Use an opening tool to push the motherboard out as shown in the picture.
    Frag FixBot
Abschluss
CSU Los Angeles, Team 5-3, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 5-3, Adachi Fall 2022
CSULA-ADACHI-F22S5G3
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 35
Insgesamt: 978
