Zum Hauptinhalt wechseln
Netgear Arlo Battery Replacement
Was du brauchst
  1. Netgear Arlo Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Netgear Arlo Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Netgear Arlo Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate unlock switch on underside of camera and unlock it by sliding it.
    • Once unlocked, slide the cover out and up to open the battery housing.
  2. Netgear Arlo Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove all 4 of the 3.0 Volt batteries from the battery housing.
  3. Netgear Arlo Battery Replacement: Schritt 3, Bild 1 von 1
    • Inspect prongs at the bottom of the battery housing to ensure that they are not bent or broken before replacing the batteries.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
IUPUI, Team S1-G1, Freund Spring 2018 Mitglied von IUPUI, Team S1-G1, Freund Spring 2018
IUPUI-FREUND-S18S1G1
2 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
i am having a problem charging my arlo pro device
JOSEPH J RUTHERFORD - Antwort
I am having a problem with one of my cameras not recognizing the batteries. I replace the battery and it says that it’s low. I’ve tried the same battery on another one of my cameras and it has a full life of energy. I am out of warranty but wanted to know if maybe I can take take it somewhere to get fixed and where???
lawendolina - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 66
Insgesamt: 6,954
