Zum Hauptinhalt wechseln
Netgear Arlo Charging Port Replacement
Was du brauchst
  1. Netgear Arlo Charging Port Replacement, Plastic Housing: Schritt 1, Bild 1 von 1
    • Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
  2. Netgear Arlo Charging Port Replacement: Schritt 2, Bild 1 von 2 Netgear Arlo Charging Port Replacement: Schritt 2, Bild 2 von 2
    • Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
  3. Netgear Arlo Charging Port Replacement: Schritt 3, Bild 1 von 1
    • Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
  4. Netgear Arlo Charging Port Replacement: Schritt 4, Bild 1 von 3 Netgear Arlo Charging Port Replacement: Schritt 4, Bild 2 von 3 Netgear Arlo Charging Port Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
    • Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
    • Make sure the plastics snaps on the front of the plastic get unhooked from the grey plastic ring around the front of the camera.
  5. Netgear Arlo Charging Port Replacement: Schritt 5, Bild 1 von 3 Netgear Arlo Charging Port Replacement: Schritt 5, Bild 2 von 3 Netgear Arlo Charging Port Replacement: Schritt 5, Bild 3 von 3
    • Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
    • Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
    • Once the screws are removed use an opening tool to pry back the second plastic mount.
  6. Netgear Arlo Charging Port Replacement, Lens Assembly: Schritt 6, Bild 1 von 1
    • Remove 4 (6mm) large screws with a J00 screwdriver.
    • There are 2 on each side. This will allow you to remove the clear housing from the white housing.
  7. Netgear Arlo Charging Port Replacement: Schritt 7, Bild 1 von 2 Netgear Arlo Charging Port Replacement: Schritt 7, Bild 2 von 2
    • Once screws are removed, pull apart the clear housing.
    • Remove rod from camera cover.
  8. Netgear Arlo Charging Port Replacement: Schritt 8, Bild 1 von 3 Netgear Arlo Charging Port Replacement: Schritt 8, Bild 2 von 3 Netgear Arlo Charging Port Replacement: Schritt 8, Bild 3 von 3
    • Remove Large ribbon cable first to disconnect front of camera from main body.
    • Remove 4 (3.5mm) small black screws from motherboard of the camera unit.
    • Remove smaller ribbon cable from underneath yellow tape.
  9. Netgear Arlo Charging Port Replacement: Schritt 9, Bild 1 von 1
    • Once all ribbon cables are removed, remove the motherboard and camera assembly by pulling up on the black camera motherboard.
  10. Netgear Arlo Charging Port Replacement, Charging Port: Schritt 10, Bild 1 von 1
    • Remove the 2 (.135") housing screws with a JIS00 screwdriver
  11. Netgear Arlo Charging Port Replacement: Schritt 11, Bild 1 von 1
    • Remove 4 (.135") screws on the inside of the battery compartment using the JIS 00 screwdriver.
  12. Netgear Arlo Charging Port Replacement: Schritt 12, Bild 1 von 1
    • Slide the two halves apart
  13. Netgear Arlo Charging Port Replacement: Schritt 13, Bild 1 von 1
    • Remove the 2 (.135") screws holding the charging port on using the JIS 00 screwdriver.
  14. Netgear Arlo Charging Port Replacement: Schritt 14, Bild 1 von 2 Netgear Arlo Charging Port Replacement: Schritt 14, Bild 2 von 2
    • Remove the ribbon by prying the black ribbon holder up using the opening tool.
    • Pull the ribbon away from the charging port.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
IUPUI, Team S2-G1, Freund Spring 2018 Mitglied von IUPUI, Team S2-G1, Freund Spring 2018
IUPUI-FREUND-S18S2G1
2 Mitglieder
4 Anleitungen geschrieben
4 Kommentare
Great Job, Thank you!
Bob Olive Sr - Antwort
Great thanks where did you get the replacement cable please thanks Mike
mikewalters1951 - Antwort
where did you get the replacement cable please thanks  BOB
robertwatkins61 - Antwort
Any hints on where the new port came from? I have the baby monitor and the port is cheap rubbish and needs replacing. Thanks
David - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 47
Insgesamt: 5,202
