Zum Hauptinhalt wechseln
Netgear Arlo Infrared LED Board Replacement
Was du brauchst
  1. Netgear Arlo Infrared LED Board Replacement, Plastic Housing: Schritt 1, Bild 1 von 1
    • Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
  2. Netgear Arlo Infrared LED Board Replacement: Schritt 2, Bild 1 von 2 Netgear Arlo Infrared LED Board Replacement: Schritt 2, Bild 2 von 2
    • Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
  3. Netgear Arlo Infrared LED Board Replacement: Schritt 3, Bild 1 von 1
    • Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
  4. Netgear Arlo Infrared LED Board Replacement: Schritt 4, Bild 1 von 3 Netgear Arlo Infrared LED Board Replacement: Schritt 4, Bild 2 von 3 Netgear Arlo Infrared LED Board Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
    • Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
    • Make sure the plastics snaps on the front of the plastic get unhooked from the grey plastic ring around the front of the camera.
  5. Netgear Arlo Infrared LED Board Replacement: Schritt 5, Bild 1 von 3 Netgear Arlo Infrared LED Board Replacement: Schritt 5, Bild 2 von 3 Netgear Arlo Infrared LED Board Replacement: Schritt 5, Bild 3 von 3
    • Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
    • Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
    • Once the screws are removed use an opening tool to pry back the second plastic mount.
  6. Netgear Arlo Infrared LED Board Replacement, Lens Assembly: Schritt 6, Bild 1 von 1
    • Remove 4 (6mm) large screws with a J00 screwdriver.
    • There are 2 on each side. This will allow you to remove the clear housing from the white housing.
  7. Netgear Arlo Infrared LED Board Replacement: Schritt 7, Bild 1 von 2 Netgear Arlo Infrared LED Board Replacement: Schritt 7, Bild 2 von 2
    • Once screws are removed, pull apart the clear housing.
    • Remove rod from camera cover.
  8. Netgear Arlo Infrared LED Board Replacement: Schritt 8, Bild 1 von 3 Netgear Arlo Infrared LED Board Replacement: Schritt 8, Bild 2 von 3 Netgear Arlo Infrared LED Board Replacement: Schritt 8, Bild 3 von 3
    • Remove Large ribbon cable first to disconnect front of camera from main body.
    • Remove 4 (3.5mm) small black screws from motherboard of the camera unit.
    • Remove smaller ribbon cable from underneath yellow tape.
  9. Netgear Arlo Infrared LED Board Replacement: Schritt 9, Bild 1 von 1
    • Once all ribbon cables are removed, remove the motherboard and camera assembly by pulling up on the black camera motherboard.
  10. Netgear Arlo Infrared LED Board Replacement, Infrared LED Board: Schritt 10, Bild 1 von 1
    • Remove 3 (.150") screws from the sync board using the JIS00 screwdriver.
  11. Netgear Arlo Infrared LED Board Replacement: Schritt 11, Bild 1 von 2 Netgear Arlo Infrared LED Board Replacement: Schritt 11, Bild 2 von 2
    • Use the plastic opening tool to slowly pry the board away from the front housing.
Abschluss
Daniel Bailey
85 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G1, Freund Spring 2018 Mitglied von IUPUI, Team S2-G1, Freund Spring 2018
IUPUI-FREUND-S18S2G1
2 Mitglieder
4 Anleitungen geschrieben
3 Kommentare
Great tutorial, thanks a lot.
I have a problem with infrared, Netgear isn’t able to help me without seeing the camera.
I would like to ask you….
In the night the red leds light on but you see all black, there is no light entering in the lens system. I think there is a problem in the diaphragm… what do you think?
The first months it works correctly (except once when I see all pink, I fix it restarted the camera).
Thank you!
Matteo
matteor84@hotmail.it
Matteo Runfola - Antwort
Where can you buy the board and other parts?
Jay Hartman - Antwort
I’d like to know too. This repair guide is no help if you can’t buy the parts needed to complete the repair.
D. Liseckas -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 2,315
