Zum Hauptinhalt wechseln
Netgear Arlo Lens Assembly Replacement
Was du brauchst
  1. Netgear Arlo Lens Assembly Replacement, Plastic Housing: Schritt 1, Bild 1 von 1
    • Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
  2. Netgear Arlo Lens Assembly Replacement: Schritt 2, Bild 1 von 2 Netgear Arlo Lens Assembly Replacement: Schritt 2, Bild 2 von 2
    • Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
  3. Netgear Arlo Lens Assembly Replacement: Schritt 3, Bild 1 von 1
    • Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
  4. Netgear Arlo Lens Assembly Replacement: Schritt 4, Bild 1 von 3 Netgear Arlo Lens Assembly Replacement: Schritt 4, Bild 2 von 3 Netgear Arlo Lens Assembly Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
    • Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
    • Make sure the plastics snaps on the front of the plastic get unhooked from the grey plastic ring around the front of the camera.
  5. Netgear Arlo Lens Assembly Replacement: Schritt 5, Bild 1 von 3 Netgear Arlo Lens Assembly Replacement: Schritt 5, Bild 2 von 3 Netgear Arlo Lens Assembly Replacement: Schritt 5, Bild 3 von 3
    • Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
    • Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
    • Once the screws are removed use an opening tool to pry back the second plastic mount.
  6. Netgear Arlo Lens Assembly Replacement, Lens Assembly: Schritt 6, Bild 1 von 1
    • Remove 4 (6mm) large screws with a J00 screwdriver.
    • There are 2 on each side. This will allow you to remove the clear housing from the white housing.
  7. Netgear Arlo Lens Assembly Replacement: Schritt 7, Bild 1 von 2 Netgear Arlo Lens Assembly Replacement: Schritt 7, Bild 2 von 2
    • Once screws are removed, pull apart the clear housing.
    • Remove rod from camera cover.
  8. Netgear Arlo Lens Assembly Replacement: Schritt 8, Bild 1 von 3 Netgear Arlo Lens Assembly Replacement: Schritt 8, Bild 2 von 3 Netgear Arlo Lens Assembly Replacement: Schritt 8, Bild 3 von 3
    • Remove Large ribbon cable first to disconnect front of camera from main body.
    • Remove 4 (3.5mm) small black screws from motherboard of the camera unit.
    • Remove smaller ribbon cable from underneath yellow tape.
  9. Netgear Arlo Lens Assembly Replacement: Schritt 9, Bild 1 von 1
    • Once all ribbon cables are removed, remove the motherboard and camera assembly by pulling up on the black camera motherboard.
Abschluss
IUPUI, Team S1-G1, Freund Spring 2018 Mitglied von IUPUI, Team S1-G1, Freund Spring 2018
IUPUI-FREUND-S18S1G1
2 Mitglieder
6 Anleitungen geschrieben
7 Kommentare
toller Tipp! Weiß jemand, wo man die Linse kaufen kann.?
familie - Antwort
Wo bekomme ich ein neues Gehäuse?
piet - Antwort
hi I took out the battery befor it was finished downloading new firmware, now there is no connection, no blue light. Can you help or is the camer garbage?
Rune Koppang - Antwort
I struggled a bit with the ribbon cable connections, they need to be lifted up from the side the cable enters. They are sort of hinged like a door but lying on its side. Once it is stood up vertically, the cable will pull out. For the longer one I found it was important to lift as much of it up at once otherwise it will break if you lift one end and not the other. Once the cable is reinserted, they can just be pushed back down, same as before, supporting the full length when you do. If one comes off it is possible to push it back onto the hinge but it is very very tricky and took a while.
Richard Bailey - Antwort
Where did you get the replacement lens?
G. N. - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 30
Insgesamt: 4,783
