Zum Hauptinhalt wechseln
Netgear Arlo Plastic Housing Replacement
Was du brauchst
  1. Netgear Arlo Plastic Housing Replacement, Battery: Schritt 1, Bild 1 von 3 Netgear Arlo Plastic Housing Replacement, Battery: Schritt 1, Bild 2 von 3 Netgear Arlo Plastic Housing Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate unlock switch on underside of camera and unlock it by sliding it.
    • Once unlocked, slide the cover out and up to open the battery housing.
  2. Netgear Arlo Plastic Housing Replacement: Schritt 2, Bild 1 von 1
    • Remove all 4 of the 3.0 Volt batteries from the battery housing.
  3. Netgear Arlo Plastic Housing Replacement: Schritt 3, Bild 1 von 1
    • Inspect prongs at the bottom of the battery housing to ensure that they are not bent or broken before replacing the batteries.
  4. Netgear Arlo Plastic Housing Replacement, Plastic Housing: Schritt 4, Bild 1 von 1
    • Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
  5. Netgear Arlo Plastic Housing Replacement: Schritt 5, Bild 1 von 2 Netgear Arlo Plastic Housing Replacement: Schritt 5, Bild 2 von 2
    • Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
  6. Netgear Arlo Plastic Housing Replacement: Schritt 6, Bild 1 von 1
    • Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
  7. Netgear Arlo Plastic Housing Replacement: Schritt 7, Bild 1 von 3 Netgear Arlo Plastic Housing Replacement: Schritt 7, Bild 2 von 3 Netgear Arlo Plastic Housing Replacement: Schritt 7, Bild 3 von 3
    • Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
    • Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
    • Make sure the plastics snaps on the front of the plastic get unhooked from the grey plastic ring around the front of the camera.
  8. Netgear Arlo Plastic Housing Replacement: Schritt 8, Bild 1 von 3 Netgear Arlo Plastic Housing Replacement: Schritt 8, Bild 2 von 3 Netgear Arlo Plastic Housing Replacement: Schritt 8, Bild 3 von 3
    • Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
    • Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
    • Once the screws are removed use an opening tool to pry back the second plastic mount.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
IUPUI, Team S1-G1, Freund Spring 2018 Mitglied von IUPUI, Team S1-G1, Freund Spring 2018
IUPUI-FREUND-S18S1G1
2 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
Where can I buy replacement parts like a battery cover for Arlo
L R Hardy - Antwort
Note that under the rubber cover shown in step 6 there is a USB-B port.
You can run the Arlo on a USB adapter as well.
You only need to make a hole in the battery lid or 3D print a new cover.
Bas Vijfwinkel - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 2,327
